Most recent update: 2022-05-23
Company name |
宇都宮工業株式会社 (Utsunomiyakougyoukabushikigaisha) |
Website URL | http://www.u-m.co.jp |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 33,500,000 JPY | Employees | 70 |
Annual sales | 2,200,000,000 JPY | EMIDAS Member Number | 22270 |
Type of manufacturing | Transportation equipment / Construction material / Jigs and tools |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) Drawing metal press die designing General metal press die 3D modeling (press) NC data creation (press) |
Designing | Jig and tool designing | Welding jig designing Mass production jig designing Automatic tool designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling Profile milling Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Laser and turret punch press processing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Form grinding Profile grinding Jig grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Forming die Progressive die Transfer press die Single press die Press robot die 60 - 300 t |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Wire spring die Leaf spring die |
Mass production | Metal press | Drawing Bending Blanking Forming Multi forming Press robot (below 80 t) Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Forging | Header machining |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrodeposition coating Electrostatic coating |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Heat treatment | Normalizing Annealing Straightening annealing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Assembly | Auto parts assembly Construction component assembly |
Parts manufacturing | Spring | Thin leaf spring |
Product manufacturing | Production property | Carrier machine manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing |
