Most recent update: 2023-06-07
Other electrical part manufacturing( Parts manufacturing / Electrical part ) |
Company name |
イースタン技研 株式会社 電気接点事業部 (I-sutanngikenn) |
Website URL | https://www.eastern-tech.co.jp/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 50,000,000 JPY | Employees | 236 |
Annual sales | 7,700,000,000 JPY | EMIDAS Member Number | 22106 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Electrical component for transportation equipment |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Electrical planning | Electrical machinery and apparatus designing PCB designing Other electronic part designing |
Material | Specialized material distribution | Clad steel |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding Plastic bonding Ultrasonic welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Manufacturing Part processing Bending die Blanking die Multi forming die Progressive die Single press die Below 60 t |
Die manufacturing | Plastic mold | Manufacturing Part processing Injection molding die Insert molding die Below 60 t |
Die manufacturing | Spring mold | Manufacturing Spring die part processing Leaf spring die |
Mass production | Metal press | Bending Blanking Forming Multi forming Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Diameter Single press (below 80 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Chromium (barrel) Gold/Silver plating Acid pickling Electroless nickel (barrel) Copper Brass Stainless steel Other anti-rust treatments Degreasing |
Surface treatment | Heat treatment | Normalizing Annealing Stress relief annealing (SR treatment) Straightening annealing Air quenching Flame quenching |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly |
Assembly/Inspection | Inspection | Metal press Plastic |
Parts manufacturing | Electrical part | Harness processing Connector manufacturing Other electrical part manufacturing |
Parts manufacturing | Spring | Terminal spring Leaf spring Stainless steel Copper alloy |
Product manufacturing | Production property | Electrical machinery and apparatus manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing Telecommunication equipment manufacturing |
