PR message
TDC’s precision polishing technology can polish down to Ra1nm on a variety of materials, including metal, ceramics, semiconductor, glass, and other materials. By applying this precision polishing, the manufacture of high precision products with achievement of flatness of 01μ, parallelism of 05μ, and straightness/step of ±05μ is possible.
Work area is 01φ~φ1500. (We are currently testing oversize polishing. If you would like to consider doing oversize polishing, please contact us for more details.)
◆Selected one of 300 Dynami Monozukuri(craftsmanship) company by METI (Japanese government)◆
◆Awarded excellent prize of IT management grand-prix. by METI (Japanese government) ◆
◆Awarded excellent prize of New business prize by Japan New Business conference ◆
TDC is a member of IVAM
TDC is able to polish various kinds materials and be able to
achieve single-nano roughness and sub-micro size tolerance at same time.
Our precision technology is applied for Hayabusa 2 project and departing to the universe in 2014.
selected as one of Japan's Global Niche Top 100 by METI
We are very proud to announce that TDC Corporation is awarded as one of “Global Niche Top Companies Selection 100.” by The Ministry of Economy, Trade and Industry (METI) Japan.
METI’s News release page: http://www.meti.go.jp/english/press/2014/0317_01.html
We will try devoting ourselves to enhancing our ability and seeking global market.
Thank you very much.
Japan's Small and Medium enterprise agency is providing new Web matching system "J good Tech" (Japan's good technologies).
TDC is introduce at the special site for introducing J-Good Tech.
Please find TDC's company details and Movie at the site.
http://www.jibtv.com/programs/jgoodtech/tdc_corporation/index.html
<<Materials>>
Ceramics: silicon nitride, silicon carbide, alumina, zirconia, silicon-sapphire, etc.
Metal: various alloys such as titanium, aluminum, molybdenum, tungsten, nickel, iron, copper, stainless steel, Carbide, etc
Resin: various engineering plastics, etc
We also work on processing new materials.
*In addition to processing delivered materials to be processed, we also procure materials and partial process on base materials.
<<Precision (only for single-sided lapping)>>
Flatness:0.1μ
Roughness(Ra):0.001μ(1 nano meter)
Parallelism:1μ
Thickness difference:±0.5μ
Workable area:φ1500mm(Max workable area)
<<Precision (only for double-sided lapping)>>
Flatness:0.1μ
Roughness(Ra):主にGCなどの梨地面
Parallelism:0.5μ
Workable area:φ250mm(Max workable area)
<<Equipments>>
Single-sided lap board/mirror processer: 12 in ~ 63 in (Supportable size ~φ800㎜) 85 machines.
Double-sided lap board: 5B ~ 15B (supportable size: ~φ250㎜) 15 machines.
From short to long roll and shaft, we will mirror polish all surfaces. We support from single piece as well as mass-production. Please contact us for details.
<<Precision>>
Periphery roughness: Ra1.5nm、Rz10nm(SUS304, glass, etc.)
We deal with the processing with Ra0.010μm or less roughness for aluminum as well.
<<Materials>>
Stainless, Titanium, Aluminum, Glass.
We can also handle coated products.
(Nickel coat, chrome coat, hard rom coat, etc.)
Our processing will guarantee to produce nano level roughness while maintaining measure precision and roundness.
From short to long roll and shaft, we will mirror polish all surfaces. We operate single piece production as well as mass-production. Please contact us for details.
<<Precision>>
Periphery roughness: Ra1.5nm、Rz10nm(SUS304, glass, etc)
We deal with Ra0.010μm or less roughness for aluminum as well.
<<Materials>>
We also can handle coated products.
We not only can lap process on different types of materials, but also can lap on coated surface or used as preparation for coating.
Oddly enough, most customers do not know that lapping can be used as pre-coating and do receive questions regards to it.
<Example1: Alumina thermal sprayed surface>
To improve precision and life of currently used surface plate, we applied alumina thermal spray which eventually led to improved flatness and surface hardness. (Recommended for those customers who are currently using cast iron surface plates.)
<Example2: Ni plated surface/NiP plated surface>
Applied lapping to Ni and NiP plated surface which then used as adsorption face, reflecting face and pattern treatment face.
(Cheap Ni and NiP platting is commonly used to gain antirust effect.)
<Example3: DLC, TiN treatment>
For those surfaces, such as adsorption face, require high specularity and harden surfaces, we applied DLC or TiN treatment to harden the surface.
<Example4: hard anodized aluminum>
We applied hard anodized aluminum onto aluminum base and then lapped anodized aluminum layer. Improved flatness and hardness. It is commonly used for adsorption face.
The picture shows the roughness of single digit nano level foil polishing. We are able to produce up to 100 meter hoop roll.
Not only may we apply mirror polish to long hoop, but also to your desired shapes (thickness of 0.001mm).
<<Precision>>
Ra1nm, Rz6nm(SUS304)
<<Materials>>
We are currently increasing our possibility for material use such as Ni. Please contact us for more details.
Precise adjustment for precision device assembling and mould jig assembling is possible.
In addition to the shape shown on the picture (standard size M2 ~ M8), we can manufacture in your desirable shapes, such as wire mesh and tapetum.
TDC’s spacer is known for its high precision measure.
It may measure up to thickness of±0.001mm/±0.0005mm.
By having mirror surface on front surface, contact surface rigidity is doubled while reducing the deformed rate to half during the tightening.
<<Prices (TDC standard shim)>>
Name/measure a (mm)/ measure b (mm)/price (yen)
M2,M3 / 3.3 / 6.5 / 420
M4 / 4.5 / 8.0 / 480
M5 / 5.5 /10.0 / 580
M6 / 6.5 /12.0 / 680
M8 / 8.5 /16.0 / 890
Each board thickness measure t (μm)
10,11,12,13,14,15,16,17,18,19,20,30,40,50,60,70,80,90,100
*May order from a single unit.
*Shipping is not included in the above price.
*All prices listed above are tax included.
Mirror polishing( Surface treatment / Polishing/Lapping ) |
Company name | TDC Corporation | Website URL | http://mirror-polish.com/?lang=en |
Street address |
Mayagi Miyagi Japan
[See map] |
Person in charge | Yuko Akabane |
Telephone number | +81-22-356-3131 | Fax number | +81-22-356-3578 |
Capital | 30,000,000 JPY | Employees | 60 |
Annual sales | 750,000,000 JPY | EMIDAS Member Number | 21078 |
Type of manufacturing | Jigs and tools / Measuring machinery / Industrial machinery | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Sintered metal Milling (resin) Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining |
Development and production of prototype/Small-scale production | Blank cutting | Thin plate (below 6 mm) Stainless steel Copper/Aluminum Ceramic |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Cylindrical mirror grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Die manufacturing | Casting die | Die-casting die |
Mass production | Casting | Aluminum alloy Zinc alloy |
Surface treatment | Polishing/Lapping | Buffing Mirror polishing |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing Single-face lapping and polishing Dual-face lapping and polishing |
