Most recent update: 2024-03-08
Company name |
備南工業 株式会社 (Binannkougyou) |
Website URL | |
Street address |
Okayama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 50 |
Annual sales | 700,000,000 JPY | EMIDAS Member Number | 20897 |
Large | Medium | Small |
Designing | Industrial equipment designing | Industrial machinery designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling Machining/Handles small-scale production (order from 1 piece) Keyway milling |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Coating Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Jig grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Chassis prototype manufacturing |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrostatic coating Aqueous coating Airless spray coating Melamine coating Urethane coating Acrylic coating Lacquer coating Epoxy coating Heat-resistant coating |
Assembly/Inspection | Assembly | Construction component assembly Industrial machinery assembly |
