Most recent update: 2011-11-07
Recommended (best match) |
Website |
Icon |
Company info
| Company name |
川口板金 株式会社 (Kawaguchibannkinn) |
EMIDAS Member Number | 20057 |
| Country | Japan | Street address |
Saitama |
| Type of manufacturing | Transportation equipment / Industrial machinery / Kitchen | Capital | 50,000,000 JPY |
| Annual sales | 4,700,000,000 JPY | Employees | 260 |
Manufacturing category info
Single press (500 t and over)( Mass production / Metal press ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
General metal press die( Designing / Mold designing ) |
| Large | Medium | Small |
| Designing | Industrial equipment designing | Industrial machinery designing Plant equipment designing |
| Designing | Mold designing | General metal press die NC data creation (press) Drawing metal press die designing Progressive die designing (auto) |
| Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) Casting Aluminum alloy Stainless steel Iron Keyway milling General-purpose lathe machining Tapping General-purpose milling Spinning |
| Development and production of prototype/Small-scale production | NC machining | Machining (horizontal) Machining (vertical) |
| Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining Wire electric discharge machining |
| Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Can manufacturing Bending (hydraulic) Bending (over 3.0 m) |
| Development and production of prototype/Small-scale production | Blank cutting | Laser and turret punch press processing Corner shearing Shearing (longer than 121.2 m) Laser processing (longer than 121.2 m) Cutting Shearing Turret punch press processing |
| Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
| Development and production of prototype/Small-scale production | Prototype processing | Bending Welding Punching |
| Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Brazing Robot welding Arc welding TIG welding (argon welding) Spot welding CO2 welding |
| Die manufacturing | Press die | Over 300 t 60 - 300 t Below 60 t Single press die Progressive die Blanking die Bending die Drawing die NC data creation Die set machining Plate machining Part processing Manufacturing Designing |
| Mass production | Metal press | Single press (200 - 500 t) Progressive press (200 - 500 t) Diameter φ0.6mm - φ9.0mm Thickness Thickness Thickness Plated steel plate Titanium Aluminum Stainless steel Iron Progressive press (over 500 t) Hydraulic counter pressure press Press robot (200 - 500 t) Single press (80 - 200 t) Single press (below 80 t) Progressive press (80 - 200 t) Progressive press (35 - 80 t) Blanking Bending Drawing Single press (500 t and over) |
| Surface treatment | Plating/Chemical conversion treatment | Acid pickling |
| Surface treatment | Other surface treatment | Teflon coating Sound blast |
| Assembly/Inspection | Assembly | Industrial machinery assembly Auto parts assembly |
| Assembly/Inspection | Repair | Die repair |
| Product manufacturing | Production property | Other industrial machinery manufacturing |
| Product manufacturing | Construction and civil engineering machinery manufacturing | Combustor manufacturing |
Kawaguchibannkinn (川口板金 株式会社)
