Chassis manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Robot welding( Mass production / Welding / welding ) |
Fiber welding( Mass production / Welding / welding ) |
Laser and turret punch punching( Mass production / Blank cutting ) |
Bending process( Mass production / Sheet-metal processing ) |
Precision sheet metal processing( Mass production / Sheet-metal processing ) |
CO2 laser processing( Mass production / Blank cutting ) |
Aluminum alloy( Development and production of prototype/Small-scale production / Machining ) |
Stainless steel( Development and production of prototype/Small-scale production / Machining ) |
Iron( Development and production of prototype/Small-scale production / Machining ) |
Company name |
株式会社佐藤電機製作所 (Satoudennkiseisakusho) |
Website URL | https://s-d-s.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 68 |
Annual sales | 1,300,000,000 JPY | EMIDAS Member Number | 20016 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) General metal press die NC data creation (press) |
Designing | Product and part designing | Office equipment designing |
Designing | Jig and tool designing | General jig designing Welding jig designing |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Drawing die Bending die Blanking die Progressive die Single press die Below 60 t 60 - 300 t Over 300 t |
Mass production | Metal press | Drawing Bending Blanking Forming Iron Stainless steel Aluminum Copper Phosphor bronze Plated steel plate Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Sheet-metal processing | Can-making Air conditioning equipment manufacturing Kitchen equipment manufacturing Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Deburring process Painting process Bender processing (flood control) Bender processing (servo) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Laser and turret punch punching CO2 laser processing Clean cut Thin plate 6 mm or less stainless Copper / aluminum |
Mass production | Welding / welding | Projection welding Fiber welding Spot welding TIG welding (argon welding) Arc welding Robot welding fixing with wax Stud welding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Chemical conversion coating Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Stainless steel Hard chromium (rack) Degreasing Colored alumite Hard alumite Hot-dip galvanizing (small-size Hot-dip galvanizing (mid-size Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) Black nickel Hard chrome (barrel) |
Surface treatment | Coating | Powder coating Electrodeposition coating Melamine coating Urethane coating Epoxy coating Metal coating |
Surface treatment | Printing and others | NC engraving Engraving Silk screen printing Laser engraving |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Office equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press |
Parts manufacturing | Spring | Thin leaf spring |
Parts manufacturing | Other parts | Sign board manufacturing |
